It is currently 13 Dec 2017, 04:39
PostPosted: 03 Nov 2017, 11:47
DE VANZARE SUNT DOAR PIESELE DIN LISTA !!!
Contact: PM & 0743 832 141
senzor ABS stanga fata 50
conducta frana stanga fata 30
maner frana de mana 50
clapeta acceleratie 200
4 guri aerisire cromate/buc 50/buc sau set 160
Sistem audio BOSE complet cu cablaj 650
ornamente interior BOSE 50
chedere portiere/buc 50/buc
cheder hayon SW 60
carenaj dreapta fata 40
rezistenta ventilator clima 50
motoras clima/bucata 100/buc
macara dreapta spate 100
macara fata stanga 100
macara fata dreapta 100
ventilator clima 150
baie ulei jts 100
chiulasa 500
radiator AC 150
radiator motor 150
cutie filtru aer 100
incuietoare capota 100
roata de rezerva subtire 100
suport cric
cric cu coarba 100
ECU+chei+butuci+immo 350
trager 150
termoflot/racitor ulei 150
capace distributie JTS 100
aparatori curea accesorii 40
arcuri stock SW 150
maner stanga spate 50
manere portiere fata 50
plasa retractabila SW 150
ochelar proiector stanga sau dreapta/buc 50/buc
conducta plastic debitmetru-clapeta 30
scut termic galerie evacuare 40
conducta racire plastic jts 100
2 faruri/buc 100/buc
caseta directie 250
aripa sofer 100
fuzete fata/bucata 150/buc
4 portiere/bucata 150/buc
capac motor JTS 80
capota motor 350
hayon 350
admisie plastic 150
rampa injectie 200
injectoare/buc 150/buc
pompa benzina JTS 250
maneta lumini si stergatoare SW 200
maneta cruise control 100
spira volan comenzi audio 150
senzor unghi volan 150
motor stergatoare 100
pompa ABS/ESP 350
servofrana 150
pompa frana 150
panou comenzi clima 150
unitate clima sub bord 300
ornament consola centrala 50
buton oglinzi 30
butoane ASR si ceata 30
lampi interior 30/buc
Alfa Romeo 156 2.0 TS
PostPosted: 22 Nov 2017, 11:39
UP!
PostPosted: 30 Nov 2017, 03:13
Update la lista
pompa inalta presiune 350
fuzete spate 150/buc
2 airbaguri cortina SW 200/buc
set brate stergatoare 50
pedala electronica acceleratie 200
vas expansiune 50
catadioptru 35
parasolare 40/buc
Senzori impact lateral 50/buc
spirala servodirectie 100
incuietoare hayon SW 100
senzor acceleratie laterala 100
motoras oglinda sofer 50
intrerupator frana si ambreiaj 30/buc
indicator central bord 50
buson rezervor 40
aeroterma cu ureche rupta 60
senzor calitate aer 50
ECU senzor stergatoare 100
senzor ploaie si parbriz aburit 100
chedere orizontale geamuri 35/buc
semnalizari laterale OEM 35/buc
antena telefon 50
jante tabla 15 5x98+3 capace 300
File comment: STOCK vs BOSE
